NI TestStand
Password Recovery For Password Protected Teststand Sequence
 Is there any way is available to unlock the Teststand sequence , in case of we forget the password.
Please suggest .
(2,741 Views)
Please suggest anyone. Can we recover the password of Locked Teststand Sequence.
(2,688 Views)
Hi PJ_CLAD
Unfortunate there is no way to recover the password which was set on Sequence. But I have found another forum post, where someone could achieve this by following this instruction, which says "Rename the User.ini file from your TestStand folder in the CFG folder, then launching TestStand SeqEditor. There should be a new User.ini file created with the default settings. ie Administrator without any password."
Regards)
________
Best way to thank is to give Kudos / Mark as a solution.
(2,667 Views)
If you mean password protected sequence file then you could try to unlock it with an API.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,646 Views)
In addition, I have left the forum post link below.
Solved: TestStand password - NI Community
Regards)
(2,590 Views)
