NI TestStand
Passing data between LabVIEW Actor Framework and TestStand
I am looking for some kind of best practice.
I have a LabView Actor Framework where I wired the main actors enqueuer to TestStand, this way I can contol the AF from Teststand.  Using the AF's send messages I can execute different sequences, power a pcb on, init a test, start a measurement.
Now I can't really find a clean solution to handle situation where I have to wait for something, f.e. a "Power On Acknowlege" ob the pcb's bus. This signal would be required to proceed the TestStand sequence to the next step. Or simply passing measurement data to TestStand for a limit test.
My current solution would be to create a variable in TS and poll it in a while loop, and write it in Labview with "TestStand - set property value.vi". This doesn't feel right.
Any Ideas?
(122 Views)
Thank you, that's exactly the solution I went for in the meantime.
Works like a charm
(54 Views)
