02-12-2021 01:07 AM
I am looking for some kind of best practice.
I have a LabView Actor Framework where I wired the main actors enqueuer to TestStand, this way I can contol the AF from Teststand. Using the AF's send messages I can execute different sequences, power a pcb on, init a test, start a measurement.
Now I can't really find a clean solution to handle situation where I have to wait for something, f.e. a "Power On Acknowlege" ob the pcb's bus. This signal would be required to proceed the TestStand sequence to the next step. Or simply passing measurement data to TestStand for a limit test.
My current solution would be to create a variable in TS and poll it in a while loop, and write it in Labview with "TestStand - set property value.vi". This doesn't feel right.
Any Ideas?
02-19-2021 02:38 AM
Pass a notifier from TS and wait.
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsexamples/infotopics/sync_notif_wait/
Also,
02-19-2021 02:40 AM
Thank you, that's exactly the solution I went for in the meantime.
Works like a charm
