NI TestStand
Passing a struct from TestStand to LabWindows/CVI
I am passing a struct to a dll written in CVI.
Here is the problem: The code is written in CVI (c code) if I use "struct MyStruct *MyData" as the parameter definition in the dll TestStand works fine. But if I define my struct using a typedef (i.e. typdef struct MyStruct) then use MyStruct *MyData as the parameter TestStand throws a warning.
I an using the C\C++ adaptor.
It is too late in the programming effort to go back and remove the typedef.
So, how do I get TestStand to accept the typedef?
Carmine
(4,040 Views)
Accepted by topic author CarmineS
In ANSI C, the struct names and type names belong to separate namespaces. You can declare structs several different ways:
1) struct structName { int x; };
2) typedef struct { int x; } typedefName;
3) typedef struct structName { int x; } typedefName; // Note: structName can be same as typedefName.
I'm assuming you are using the 2nd example above in which case LabWindows/CVI automatically generates a struct name (something like __unknown_1) that Testand uses.
Although you said it is too late to remove the typedef, can you add a struct name as in example 3 above? You can use the same name as the typedefName and TestStand will recognize it.
(4,009 Views)
Thanks a lot. I made the modification to the struct definition and it is working.
Erik,
Thanks for the quick reply.
Carmine
(3,988 Views)
