NI TestStand
Passing Sequence arguments to an execution using a process model
solved.
I figured out how to pass sequence arguments through the process model.
thx to everyone
thx
Marcos V. Bischoff
Message 11 of 13
(1,161 Views)
Hi Marcos,
That sounds good. But just for the members here and myself, too. How did you solve it ?
Please explain it in a few words.
Greetings from the Lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 12 of 13
(1,152 Views)
How, did I to it?
"I enpowered my will and forced my binary slave to obey my commands." 😉
No, seriously. To problem was, as already mentioned in this thread, that the used process model did not pass the commands. Because the MainSequence callback did no call its subsequnce using any parameters. I changed that, for it passes a mere container to the subsequence. Waht made it a bit trickier, is that i wanted an universial solution not only for a defined set of parameters but for any set of parameters our sequence would need. Therfor I am filling the container within our faceless UI by using the TS API and adding to the ProcessModel.Sequence.Parameters (this.myProcessModelFile.GetSequence(0).Parameters) PropertyObject the needed container with the needed arguments. The trick is to deactivate the Flag (PropFlags_DontTypeCheckParameter–(Value: 0x80)) as for our need the processmodel has an nearly empty container (I added a count variable to detemine how many arguments it contains) and the sequence expects it's own formated container.
Actually that was it. The rest, how I determine which arguments to add, and so on  isn't part of the answer to the question anymore.
thx
Marcos V. Bischoff
Message 13 of 13
(1,145 Views)
