06-02-2020 06:33 AM
I have a SequenceA and a SequenceB and also some SubSequenzes like SetTime, SetGetTime, GetTime
Now I would like to pass a sequence as a parameter such as SetTime
Example:
SequenceB.Parameters.TimeSesequence (TimeSeuqenz is the method call for SetTime, GetTime, SetGetTime)
Ist this possible?
06-02-2020 08:50 AM
Is specifying a sequence by expression is what you need or passing a reference to the sequence?
06-02-2020 10:04 AM
06-02-2020 11:26 PM
The second one.
Thanks james, but how can I pass sequences if they using parameters?
06-03-2020 03:13 AM - edited 06-03-2020 03:17 AM
Try this
Locals.Sequence = RunState.SequenceFile.GetSequenceByName("SeqName")
Locals.Sequence.AsSequence.Parameters.MyParameter = 666
Locals.Sequence - your local reference to the sequence
MyParameter - sequence parameter name (number in this case)
06-03-2020 11:27 AM
To pass parameters, go to the sequence call step's module pane and click on the Load Prototype button (curved blue arrow icon button on the far right). Select an example of the kind of sequence you want to call and the parameters will appear.
