NI TestStand
Pass a 2 Dimensional String Array to VB.Net
I'm trying to pass a 2 dimensional String Array from TestStand 4 into VB.Net (2003), however the array in VB.NET is somehow in the wrong format.  The array size varies:
Array size is set by:
  SetArrayBounds(Locals.asArray,"[0][0]","[5][" + Str(Locals.nMaxSize) + "]")
The Locals.asArray is then passed into a VB.NET function and instead of the array being:
  [0][0] = "Name1"
  [1][0] = "Attribute"
  [2][0] = "Default"
  [3][0] = "Class"
  [4][0] = "Member"
  [5][0] = "Instance"
  [0][1] = "Name2"
I seem to get something like:
  [0]="Name1"
  [1]="Name2"
Is there a way to pass the array in a format that VB.NET will understand?
    I also need to Pass a similar array from VB.NET back to TestStand 4
Mike
(4,368 Views)
Hi Mike,
Would it be possible for you to attach an example sequence file and VB.NET project that displays this behavior?
Manooch H.
(4,246 Views)
Mike,
Did you get this issue resolved? Were you able to successfully pass the 2D string array from TestStand into VB.NET?
Manooch H.
(4,061 Views)
