03-20-2018 09:58 AM
I want to open a VI with one call from a TestStand step and close the vi from another TestStand Step. I want to store the vi reference back in a TestStand FileGlobal using the SetPropertyValue vi and retrieve the vi reference with the GetPropertyValue vi.
I've found that if I simply pass the vi reference that the prototype in TS makes it a U32 type and it works perfect. I don't want the user of my step type to have to manage the storage of the vi reference so I want to save it away with the SetPropertyValue. If I try to make the SetPropertyValue instance be of type U32 the VI breaks and won't attach. I found that casting the vi reference to a U32 works and the value passes. But when I pass it back into the close vi the value is incorrect and the close vi errors.
How can I pass a vi reference in and out of TS using the Get/SetPropertyValue vi?
Mick
03-20-2018 04:42 PM
Why not run it in a new thread and then close it by setting a variable? This is typically how it's done.
There are hundreds of examples out there if you google: Run VI in New Thread TestStand
Maybe I don't understand your purpose? If you explain why then maybe I could give a better answer.
03-20-2018 04:44 PM
Here's an example.
03-21-2018 07:55 AM
Thanks for the advice. I think with a little code rewrite I can use the method of launching the vi in a new thread and monitoring/writing TS variables.
I'm still not sure why I cannot pass the VI reference but the method you recommended is just as good a solution.
Mick
03-21-2018 01:24 PM
After some trial and error I've found that the new thread technique is not going to work for me. The issue is that to create a new thread requires calling a seq call. I need to create a step type that calls a vi. I don't believe there is any way to call a step type in a new thread.
How can I pass the VI reference from/to TS using Get/SetPropertyValue in LV?
Mick
03-21-2018 02:32 PM
You can do it in one step if you use the Run VI Asynchronously step in TestStand.
It's down on the bottom in your palette in the LabVIEW Utility folder.
