01-16-2014 10:26 AM
HI,
I want to change parallel test uut screen. How can i do it?
01-16-2014 11:26 AM
01-16-2014 11:36 AM
01-16-2014 06:18 PM
01-18-2014 02:47 AM
I dont use c complier. do you have trial version
01-18-2014 03:27 AM
I download CVI. Which file include parallel test UUT screen?
01-18-2014 11:18 AM
01-20-2014 09:12 AM
Ergin,
On my machine with TestStand 2013, the Parallel UUT dialog is in a file called paralleluutdlg.c at the following path: C:\Program Files (x86)\National Instruments\TestStand 2013\Components\Models\TestStandModels. Your path may differ slightly if you're on a 32-bit machine or if you have a different version of TestStand.
What type of change are you wanting to make to the dialog?
01-20-2014 10:50 AM - edited 01-20-2014 10:50 AM
You can also just override the dialog with code in a sequence using callbacks, replacing it with whatever you want. See the example:
<TestStandPublic>\Examples\ProcessModels\ParallelModel\OverrideSerialNumForParallelModel.seq
-Doug
01-20-2014 03:04 PM
Thanks for help. I want to change parallel uut screen. I did it with labwindows/cvi. 🙂
