NI TestStand
Packages based distribution in TestStand 2017 deployment utility
Hi
I am trying to use the new “Package based distribution” feature in the TestStand 2017 deployment utility, but the option is always disabled. This must mean that I am missing some components in my installation, but I cannot figure out which. I have installed the NI Package Manager but that did not change anything. I tried to reinstall TestStand after installing the NI Package Manager but no change.
I hope some one in here can help set this up to work, thanks.
Best regards
Jens Christian Andersen.
CLA, CTA, CPI
(2,056 Views)
Accepted by J.C._Andersen
I understand that it is only available in the 64-bit version. Which bitness do you have?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,030 Views)
If this is the case, then that is why it does not work. I use the 32 bit version.
Thank you for the answer.
Best regards
CLA, CTA, CPI
(2,018 Views)
