08-17-2017 11:54 AM
I have an issue with NI PXI 1031, when a turn on the pxi work a time but after the pxi turn off the fan power and there isn’t current in the power slots and the source does not work, only the indicator leds of chassis keep on. I don’t understand what happened with the pxi.
Additionally, I can see that pxi work only when one led is on, but after a time all leds on and the power supply stops working.
Attach the pictures.
Anybody can help me.
08-18-2017 10:30 AM
Hi marco_f7
It appears as if your fan is dead. According to internal documentation, when only one LED is on (like in your first picture), the fan is set to HIGH, which is fine, but when all the LEDs are on (like in your second picture), the fan is dead, which corresponds to the behaviour you are describing. You will need to send in your chassis for repair. Please contact National Instruments by phone to create your repair order.
06-12-2019 11:40 PM - edited 06-12-2019 11:45 PM
Dear colleagues!
Please help me, I didn't understand, with an empty and serviceable PXI-1031 the fan should work or not ?
Or in other words, not working fan with an empty PXI-1031 is talking about that PXI-1031 should be sent for repair?
