Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
04-20-2009 03:41 PM
Solved! Go to Solution.
04-20-2009 03:52 PM
I don't believe that any of the run-times are downloadable and trying to run a version 2 sequence with a 4.0 run-time would not work.
There are a lot of license issues and you should probably contact NI directly with your serial number.
Thanks!
We'll be in touch soon!
