NI TestStand
Operation Failed [Error Code -17500]
I'm getting this message every once in a while....
This last time, it happened after a test was passed.  I selected a few test to run as 'Single Pass' and got this error when the test began.
I was running the TestExec provided with the TS3.0 package. The code is in CVI7.0.
What may cause this error?
Rafi
(3,388 Views)
Hi Rafi2003,
http://digital.ni.com/public.nsf/allkb/DE2EA5FF70C904E986256D1D00779F15 this link points to a problem trying to create a temp file as the reason for the error. Are you doing something similar in one of the selected steps?
If you select the same steps, is the problem repeatable, and can you narrow down which step maybe the cause?
I assume, as you specify the testexec, you are running in either a default or custom Operator Interface. Do you see the same problems when you run in the SeqEditor?
Regards
Ray Farmer
Regards
Ray Farmer
(3,384 Views)
