08-09-2017 02:12 PM
Does anyone know of any obvious reason why I would suddenly see errors with logging TS results when switching to OTF DB logging. I can log results to DB perfectly fine using the post process logging but when attempting to use OTF logging, I get errors almost as soon as a sequence starts executing.
08-10-2017 09:37 AM
What errors are you getting when the sequence starts executing? It could be a variety of different issues, so I don't want to make assumptions quite yet on what it could be.
-Ryan M
08-10-2017 10:16 AM
Yea that's the problem, I don't know. We were looking into switching our reporting to DB vs XML and were seeing if it would be a simple switch. Unfortunately the system had to be shipped so we just kept XML and tabled the switch to DB logging for the time being so I haven't had anything to do do any significant analysis. I was hoping, though didn't expect that there might be some well known issues with OTF DB logging. But without the system now it's somewhat moot.
