03-07-2009 06:59 PM
03-09-2009 08:58 AM
Ken,
You can use a shortcut to launch your OI and pass the list of sequences as input parameters.
i.e.; Testexec.exe "sequence 1.seq" "sequence 2.seq" "sequence 3. seq"
launch TestStand from the command line with seqedit /? to see a list of command line flags that are available to use with the TestStand engine.
-Jack
03-12-2009 11:05 PM
Jack,
Thanks for the suggestion but it doesn't work. I'm using a frontend call back sequence to get user information. Using that information (probably stored in a station global) I want to preselect (high light) the prefered sequence file. However I want to preserve the option to select a different sequence file in the operator interface.
Perhaps the natural way to do this for other front panel controls is to use a control reference to get at the value property. That doesn't seem possible with Labview/TestStand.
03-13-2009 11:42 AM
ken,
Since I don't know enough about your architecture, I am going to give a couple of different approaches.
First, I'd like to confirm what you're trying to do. You'd like to load a list of sequence files, based off of who is the logged in user, and then automatically have one of them selected, also based off the current user.
There are two ways that I can think of to accomplish this.
If you could provide a bit more information about your UI and LoginLogout architecture and the exact funtionality you are looking to implement, I can try to give you more detailed explanations and ideas.
03-14-2009 07:50 PM
Josh,
I considered the MRU approach but rejected it for the reasons you mention. What I am trying to do is to suggest, but not force, a sequence file selection based on input received in the front end call back. This input is not the logged in user but other information gathered by a pop-up window called in the front end call back. However this detail is probably not important. I had wondered if the last opened sequence file is guarannteed to be selected and you seem to confirm this. Programmatically opening sequence files in a different order so that the suggested file is opened last is close to what I want. The down side is I would prefer the operator interface to always present the operator with the sequence files listed in the same order.
Thanks for the additional information.
03-16-2009 09:37 AM - edited 03-16-2009 09:42 AM
Ken,
I just thought of something else that may help. Though you don't say what programming language you are using to build your UI, I think that this should be standard regardless of which one you're using.
When the application manager opens a sequence file, one of the events that is run is the DisplaySequenceFile event. If you look at the callback code for this event, you will see that the SequenceFile property of the SequenceFileViewManager is being set. So the reason that the last SequenceFile is the one selected is because it is the last one to run this event and therefore set this property.
If you wanted to load your sequence files in the same order every time, then it should be possible to do that, and then set the SequenceFile property of the SequenceFileViewManager to the sequence file that you would like to display.
EDIT: I just found something else that might do what you want. From your callback, you could post UIMsg_OpenWindows with the sequence file you want to display as the ActiveX paramter or the string parameter.
Let me know if I've been unclear and I'll see if I can work up a simple example.
03-19-2009 08:55 PM
OK, I think I've got it.
Use the SequenceFiles property of the Application manager to get a collection of sequence file objects. Use the item method of the collection to get the sequence file object of interest. Then set the sequence file propery of the SequenceFileView manager to the chosen sequence file object.
Thanks.
07-16-2012 11:39 AM
Ken,
I've got the same type of problem. Can you share what you did in an example?
Jon
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
