That is dictated by whatever is in Numeric Format in the Step Settings under Limits. Check out the screenshot. You can click on the drop down and customize to whatever you'd like using the standard c style string syntax.
Hope this helps,
jigg CTA, CLA testeract.com ~Will work for kudos and/or BBQ~
