Hi TomcatG
I'm interested if you are still seeing this issue?
I tried to replicate the issue on my machine, copy and pasted the result filter expression you have below and was able to execute fine and generate an ATML report (with Passed/Failed results only and no flow control).
Can you give us more information about your other result settings and the sequence that you are running?
You say you sometimes get a runtime error, how often? Is it associated with any sequence or conditions?
Dane S.
Product Support Engineer
