10-08-2025 12:05 AM
I get this 404 also, nevertheless Nigel is reachable and communicates on my PC
10-08-2025 12:13 AM
Couple of updates:
There is a new patch for Nigel that was released last week and can be installed via NI Package Manager. See How to Update the Nigel AI Assistant for Log In Issues - NI for more details.
The url that Nigel needs to access is tnm.emerson.com/nigel/login. I missed the last part in my previous post.
As a reminder you need to have an active SSP attached to your ni.com account to use Nigel.
Anand Jain
NI
11-11-2025 04:16 PM - edited 11-11-2025 04:18 PM
Our URL blocker typically blocks whole domains. What would be the repercussions of blocking all tnm.emerson.com? Are there other services either present or planned that use this domain?
12-10-2025 07:27 AM
thank you for your help working out this issue.
I ran into a similar problem. With the updated version of Nigel I am still not able to use it. I do have access to the login link you shared. When I open it it shows "Login succeeded". So I don't believe that is the issue.
I also tried to get the SSL to work. I found a certificate file through a query as you ca see below.
When I submit with "OK" and try to use Nigel it does not show results because the SSL-connection could not be established.
How do I make sure the SSL connection is working?
Thank you very much!
Kind regards
Helene Coleby
01-21-2026 04:24 AM
Dear all
I cannot login to Nigel chat AI.
I just got "login succeeded" message without logging in really.
Please see the attached screenshot.
Thank you in advance.
01-23-2026 04:43 AM
Today, I tried to login from TestStand.... at first login doesn't seem to react at all, after some time an unrendered version of NI.com is shown in the window
