Nigel™ AI Advisor - Login not working
I get this 404 also, nevertheless Nigel is reachable and communicates on my PC
Message 11 of 16
(2,307 Views)
Couple of updates:
There is a new patch for Nigel that was released last week and can be installed via NI Package Manager. See How to Update the Nigel AI Assistant for Log In Issues - NI for more details.
The url that Nigel needs to access is tnm.emerson.com/nigel/login. I missed the last part in my previous post.
As a reminder you need to have an active SSP attached to your ni.com account to use Nigel.
Anand Jain
NI
Message 12 of 16
(2,301 Views)
Our URL blocker typically blocks whole domains. What would be the repercussions of blocking all tnm.emerson.com? Are there other services either present or planned that use this domain?
Message 13 of 16
(2,105 Views)
thank you for your help working out this issue.
I ran into a similar problem. With the updated version of Nigel I am still not able to use it. I do have access to the login link you shared. When I open it it shows "Login succeeded". So I don't believe that is the issue.
I also tried to get the SSL to work. I found a certificate file through a query as you ca see below.
When I submit with "OK" and try to use Nigel it does not show results because the SSL-connection could not be established.
How do I make sure the SSL connection is working?
Thank you very much!
Kind regards
Helene Coleby
Message 14 of 16
(1,969 Views)
Dear all
I cannot login to Nigel chat AI.
I just got "login succeeded" message without logging in really.
Please see the attached screenshot.
Thank you in advance.
Message 15 of 16
(1,681 Views)
Today, I tried to login from TestStand.... at first login doesn't seem to react at all, after some time an unrendered version of NI.com is shown in the window
Message 16 of 16
(1,650 Views)
