05-22-2019 04:45 PM
I would like to send command like "netsh wlan show profiles" from a command line using Call Executable step.
But when I send the command "netsh" I get a prompt as "netsh>", so it get me into the net shell and it get me an error.
Is it possible to send net shell command from TestStand?
If not, can I do it from Labwindows/CVI?
05-22-2019 05:37 PM
I was able to make it works.
I set the File Pathname: C:\windows\systems32\netsh.exe and for argument: "wlan show profiles"
I get the answer from a string variable that I set as output destination.
