Hi robbjp,
Josh is absolutely correct in that you will get a much faster response if you post in the appropriate forum. To address your question, I would strongly recommend a different module if you are planning to make low voltage DC measurements. Take a look at the
specifications for this module. Navigate to the Common Questions portion (Appendix B-1). You will notice that the SCXI-1104C has a fixed gain of 0.1, because the module is meant for higher voltage than the DAQ card can read (up to 60 V). I would recommend going with the SCXI-1102B, which has programmable gain settings (up to 100).
Message Edited by RT4CY on 09-24-2008 04:35 PM
Rod T.
