09-03-2012 03:27 AM
09-04-2012 03:59 PM
Hi Juergen,
Unfortunately there is no built-in type to parse .xml excel files, only the .xls and .xlsx files are supported, as you mentioned. However, you could create a custom XML type to read this data. To do so, open the Types tab in the configuration window, and click the New XML Type button at the bottom left.
Refer to the Types topic in the Requirements Gateway help for more info on creating and customizing types.
