NI-DAQmx9.3 PCIe6535/6/7
The above NI is in one of the Baggage scanner which I service and maintain-Rapiscan systems.Recently it showed an Error:FAILED TO INITIALIZE.DATAIO MODULE.
I have tried all the possible tests to no avail.please assist.
(3,265 Views)
I think you may have posted this in the wrong forum, unless you baggage scanner runs TestStand, which is highly unlikely.
If the system has been running for a long time and suddenly gives this error, it is most likely a hardware error. Maybe PCI Express card in the PC has jumped out of its socket or is has just suffered a defect. I could also be the PC which has suffered a defect. I hope this helps.
Cheers
Jens.
Best regards
Jens Christian Andersen.
CLA, CTA, CPI
(2,938 Views)
I have same problem,till moment i did not get solve,can you help me ,i am maintenance in rapiscan system
(1,357 Views)
If there were no OS or Software Updates that led to this failure, I would consider it as a hardware failure and replace the board.
Before doing the replacement, try moving this DAQ to another system and see if it works there, if it does not then it is a failed card.
Santhosh
Soliton Technologies
(1,353 Views)
Hello freinds ,i have problem on rapiscan x ray machinescreen ,there are lines on picture ,i cleaned Adc and x ray generator  .x ray machine was in stors for 2 month
(1,330 Views)
And did you try changing the monitor?
Santhosh
(1,321 Views)
