NI TestStand
Multiple Conditions In "If" Flow Control Statement
I want to execute a number of tests in my sequence "if" the value of one of one of my locals is not equal to any string from a list(array) of strings. I have tried this but it doesn't work. Can anyone help?
Locals.ECU_Config_ECU_Info.ECU != ("CGW","CGW(7DF)","SimCGW","EthCGW","DASy","SVC3","MCS2")
(165 Views)
Accepted by crossrulz
Try the Contains() function.
Contains({"CGW","CGW(7DF)","SimCGW","EthCGW","DASy","SVC3","MCS2"},Locals.ECU_Config_ECU_Info.ECU)
GCentral
(153 Views)
Highlighted
This worked perfectly. I could not find mark as solution unfortunately, so I gave Kudos instead.
(78 Views)
That is because you are not the OP.  Do you use multiple accounts?
GCentral
(55 Views)
