07-18-2019 06:42 AM
Hello.
when using the MultiUUT feature of Teststand - do the local variables then exist 4 times and can have different values for each execution while executing?
07-18-2019 09:55 AM
Correct!
FileGlobals can also be treated the same. Depending on what you set for Sequence File Globals property in the sequence file properties. They can also be shared.
07-18-2019 10:13 AM
Hi jigg,
To understand you correct: That means the settings for the FileGlobals are also valid for the Local variables? Means, there is no extra parameter that must be set?
07-18-2019 02:21 PM
No. FileGlobals have a setting and can be shared if desired. Locals cannot be shared ever.
Hope that clarifies.
If you need to get data from a Local to the other threads I would recommend using Queues or sharing FileGlobals.
