05-30-2018 03:12 AM
Hi
I made the following small changes:
But I can't get the Execution View to be updated
I don't know exactly why and I don't know exactly how to correct it.
Does anybody has any Idea?
These are the main changes I made:
Regards.
05-30-2018 08:40 AM
It worked fine for me when I hardcoded a path into the sequence file path (because I didn't know what your element functionality was doing). The execution view updated correctly.
See attachment.
05-30-2018 09:16 AM
Thank you for testing it.
I tried with the path directly connected but it doesn't work.
I tried both with a dummy sequence File that just calls another VI and with my actual Sequence File and it doesn't show anything.
Do you think it may have something to do with my Station Options configuration in Teststand?
05-30-2018 09:46 AM - edited 05-30-2018 09:48 AM
I found the problem.
This is embarrassing but the Enable Tracing in the Station Options was not set true.
Thanks again!
(Should I mark the solution as Solution? It was a really silly question)
05-30-2018 11:18 AM
Glad it is working!
