10-14-2019 04:04 AM
Hi all, we just switched from TS global environment to specific environment. After startup using specific environment no step properties, except the Results-Container, appear in the Steps PropertyBrowser. This behaviour applies to all step types, NI-steps and custom ones. After checking the types-pane all pointers to types files seems to be correct, but all step types (Ni_types.ini / Action f.e.) also only shows the Results-property and some step-specific properties. It looks like some generic definitions are missing...
Wenn I start TS using global environment, everything works fine.
Does anybody have some experience with this issue or could help?
Version: TS2016 SP1
Thanks..
Solved! Go to Solution.
10-14-2019 03:49 PM
Configure>>Station Options>>Preferences>>Show Hidden Properties
Looks like that isn't part of your local environment.
10-15-2019 12:29 AM
Hmmmm... 🙂 Thanks... I never recognized this checkbox 🙂
