12-09-2011 02:20 PM
I store the response string from message pop using
Locals.ResponseValue= AbsVal(Step.Result.Response))
ResponseValue should be numeric (between 0 to 999), how to test if response entered is string?
Solved! Go to Solution.
12-09-2011 03:29 PM
Edit to original post:
Checking to see if VAL() returned 0. If zero then not a valid number. Only issue that it will ignore 0 also.
Not sure if there is a better way to do this?
TIA.
12-09-2011 04:49 PM - edited 12-09-2011 04:49 PM
you could check if this condition is true:
Str(Val(x))==x
this will return true for valid numbers, false for anything else.
