02-12-2020 04:19 AM
Hi all,
After a long period of development, I'm testing the robustess of my process in loop.
I get a memory increasing of around 100MB during 15 hours.
It's quite a lot and I need to fix it for production usage.
I'm using TS2019 with a custom OI developed in LV2019 (I don' t have the source code of this OI)
I'm using a lot of .NET code modules so to investigate, I run OI under Visual Studio debugger to profile memory usage.
I don't see any CLR memory leak.
But when I close OI, I get a TS memory leak warning like that :
"References to PropertyObjects were not released properly.
Total number of objects: 163367
Number of top-level objects: 647"
I think a lot of TS object has not been released during my loop test.
But I don't know why and I don't know how to get the root cause.
please, can someone help me and give me some way to investigate on this issue.
Thanks in advance for your help
02-13-2020 03:25 AM
Hello maxmont
How does the memory behave when you execute the sequence with the TestStand Sequence Editor?
I would test this to make sure the problem is not coming from the OI.
Chris
02-13-2020 06:56 AM
Hello Chris,
Thanks for your response.
I get the same warning message (memory leak) after I run sequence in SeqEdit and when I close SeqEdit.
Maxime
02-14-2020 04:05 AM
Hi Maxime
I would use the TestStand Sequence Editor to test individual code modules one after another. That way you can find out who is responsible for the memory leak.
Chris
02-14-2020 05:49 AM
I ve found the root cause of this memory leak TS message. I stored execution object into a TS Queue in order to be used by a thirdparty application.
So, at the end of execution, TS was not able to release it.
For moment, I remove this object storing. and the message doesn't appear anymore when I close SeqEdit or OI.
In parallel, the burnin test under OI have an anormal memory consomption (memory leak).
I ve prouve with a simple sequence file that the issue is due to OI itself.
Now, I will work with OI developer to troubleshoot this issue....
