I have a Dialog Based MFC Program, which is made using Ni ApplicationWizard, communicates to NIDAQ Hardware, Serial I/O VISA, GPIB Visa. I want to make a DLL of this program, so that the routines can be called in the testStand Sequence.
1) What is Type of Dll I should make
Extension DLL - dynamically Linked to shared MFC Library.
or
Regular DLL - dynamically Linked to shared MFC Library.
Any Examples typical making DLL in Measurementstudio for using AI_READ, AO_WRITE..?
2) I was going thru a Artical in the KnowledgeBase on NI web site "How Do I create a Type Library using Visual C++?" Document Id:1P68ATSR dated :09/07/99, updated: 09/28/2000
I have download the example and trying to understand the same,
I have follo
wing doubts,
1)In order create the typelib, Using which wizard I shoud open the project. How do I create the *.ODL file.( Basically what are the initial steps to follow?)
or I have to create a empty workspace and add .ODL file and .cpp file?
Any idea or example about how he has created/opened the project TypeLibrary.dsp,
"CreatingTypeLibraries.zip"
Pls. discuss.
