NI TestStand
Make a sequence call with a variable
Hi!
I was wondering if there is any way to use a variable to call a sequence. So instead of typing in a specific sequence in the sequence call step, is it possible to use something like CurrentValue.String to choose what sequence should run?
Thank you
(2,782 Views)
Accepted by topic author q-bertsuit
You can check the checkbox "Specify By Expression" to determine the sequence which should be called. You can use variables in the expression.
Norbert
Norbert
Expert: Geometry
(2,779 Views)
Thanks alot!
(2,773 Views)
Is it possible to set the checkbox "Specify by expression" in a statement ?
The statement should be in the cleanup or in the setup.
If yes, what is the code line to write ? because this variable is not in
the variable window so I have no idea about how use this boolean.
(2,714 Views)
