Hi everyone,
I'm using a custom Model derived from the sequentialModel (that's a requirement).
I need to run the same sequenceFile in a parrallel mode. My sequence contains only a step with a custom loop, if I change programmaticaly the LoopWhileExpression in one thread, it also changes all the other thread running the same sequence, how can I prevent that ?
Is there any way to change the LooWhileExpression in one thread without an impact on the others ?
Thank you !
