NI TestStand
Looking for a deployment solution
We are looking for a way to deploy TestStand applications to multiple test stations for multiple UUT's. We'd like to decouple the solution from our version control system by "pushing" files from version control to a "release" server. The test stations would then run some type of client application that would "pull" any new or missing files required to test the current UUT. The release sever will have a directory of common code as well as project specific directories, so the client must have a list or bill of materials that specifies what files are required for each UUT. I've written code to do this kind of thing before at my previous company, but I would like to find an off-the-shelf or open source solution if possible. Suggestions?
(3,242 Views)
Hi Mark,
Just searching the Internet I found a few different "software release management" solutions that fit the description that you put forth. I can't guarantee that they will all work with TestStand and that you won't have to design into your system solution some features to make it comply with the release management model, but here is one example of a package like this that you can start looking at:
http://www.cs.colorado.edu/serl/cm/SRM-long.html
Jason F.
Applications Engineer
www.ni.com/ask
(3,242 Views)
