NI TestStand
Logging a Result from a generic sub sequence
I have created a sub sequence that I wish to treat as a single test.
The sequence contains several reusable Labview VIs.
I have created parameters to pass in the arguments to run the test.  The outputs from the tests are recorded in a byRef parameter called "ResultsArray".  I can then call this sequence several times within my main sequence as its own test.
The problem is that I want to process the results array two ways:
  • Sometimes I want the results array to just log one or more of the entries in the report
  • Sometimes I want to perform a Pass/Fail on one or more of the results
So essentially, I want to treat this sequence like a P/F test, where the sequence itself is generic, and all the P/F logic is configured in the main sequence.
But when I try to do this, I find that the post-expressions and log additional results are unable to access Paramaters.ResultsArray, even though it's passed by Reference.
Can I do this?  Or do I need to pass those results back to a FileGlobal and parse them in a separate step?
EDIT:  To be clear...
I am able to log the entire array of strings parameter by clicking the [OUT] version of it in the Additional Results portion.
However, I would like to be able to:
  • Extract one or more of the results from that array and record the result under a specific name
  • Extract one of more of the results from that array and execute some type of limits/logic and P/F the sub-sequence as if it was a test
Right now the only thing I can think to do is to pass the results array into a generic Locals container and write a separate P/F tests to process it.
Message 1 of 1
(709 Views)
