06-10-2021 04:53 PM - edited 06-10-2021 05:37 PM
I have created a sub sequence that I wish to treat as a single test.
The sequence contains several reusable Labview VIs.
I have created parameters to pass in the arguments to run the test. The outputs from the tests are recorded in a byRef parameter called "ResultsArray". I can then call this sequence several times within my main sequence as its own test.
The problem is that I want to process the results array two ways:
So essentially, I want to treat this sequence like a P/F test, where the sequence itself is generic, and all the P/F logic is configured in the main sequence.
But when I try to do this, I find that the post-expressions and log additional results are unable to access Paramaters.ResultsArray, even though it's passed by Reference.
Can I do this? Or do I need to pass those results back to a FileGlobal and parse them in a separate step?
EDIT: To be clear...
I am able to log the entire array of strings parameter by clicking the [OUT] version of it in the Additional Results portion.
However, I would like to be able to:
Right now the only thing I can think to do is to pass the results array into a generic Locals container and write a separate P/F tests to process it.
