NI TestStand
Logging Result to Data Base
I tried to logging to the Oracle data base from TestStand.
and I got an error:
An exception occurred calling 'LogResults' in 'ITSDBLog' of 'DBLog 1.0 Type Library'
An error occurred while setting a column value.
Schema: Oracle 8 (NI).
Statement: STEP_RESULT.
Column: ID.
Object was open.
Source: TSDBLog
-2147217915; User-defined error code.
I am using the NI schema for Oracle8
Do you know what is the problem ???
(3,140 Views)
To header -
I have never been able to reproduce this error before when another customer described it, but when the customer upgraded the Oracle client software to the latest ODBC driver or OLE-DB provider, the problem went away. I think that they used ODBC instead of the OLE-DB Provider. You should be able to use version 8 or 9 client software on a client system to communicate to a 8 server. I have tested are 8.1.7.6.0 ODBC driver and the 8.1.7.2.0 OLE-DB driver that you can get from Oracles web site.
Scott Richardso (NI)
Scott Richardson
https://testeract.com
(3,140 Views)
To all who read this post:
The user's problem was solved by upgrading to Microsoft Data Access Components (MDAC) v2.7 available at the following web address:
Link -> http://www.microsoft.com/data/download.htm
Jason F.
www.ni.com/ask
(3,140 Views)
