NI TestStand
Log step in PreUUT
I try to log data in PreUUT seq.
Even if i mark it in additional data pane, i don't see it in the report.
How should i do it ?
(4,150 Views)
Accepted by topic author NikolajEgeskovOstergaard
Reporting is a feature of the model.
Normally only the ResultList from MainSeqeunce is generated to the ReportFile.
That means if your stuff if in PreUUT must be reported to the UUT file you have to modify your model.
Depending on your requirements there a lot of possibities to do that.
A simple one that worked for me for specific SequenceFiles (Note: not for all ! ) :
Copy PreUUT's ResultList to a FileGlobals ATFER it has been performed by EntryPointSequence.
Add a Statement to your MainSequnce where you add the List from RunState.Root.FileGlobals. as element to Locals.ResultList
Thats all
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,142 Views)
Ok - that should work.
Does that mean the process model "ignores" the "LOG" flag in the module definition when i'm in PreUUT ?
At least i can't see any changes when togling then flag.
(4,108 Views)
it depends on your model.
Typically, in default Sequential Model that comes with TS, only stuff from/inside MainSequence
will be reported to file.
Juergen
--Signature--
(4,089 Views)
