I tried to log an array of Numbers [0...999] into a SQL Server Database with the schema "Generic Recordset (NI)" and get the attached Error. If I don`t log the array, everything works fine.
Has anyone make the same experience or knows how to solve this problem?
If you google the error code, you will find something about a MySQL Database, but this doesn´t fit to the SQL Server Database.
(https://zone.ni.com/reference/en-XX/help/370052W-01/tsfundamentals/infotopics/database_known_issues/)
Thanks for your help.
