08-04-2014 09:24 AM
Hello All,
Trying to figure out how to turn a popup message into a test (i.e. the button that is hit determines if the test passes or fails). I am able to retrieve the result and control data flow based on the result, but can't figure out how to include the result in the report. I've been working on a "Custom Result" in the "Additional Results" section of the proerties tab, but can't seem to get the expression syntax right. Please advise. Thanks.
GSinMN
Solved! Go to Solution.
08-04-2014 09:37 AM
You can use the Status expression to determine a pass/fail result. See attached sequence for an example.
Hope this works for you.
Mathijs
08-04-2014 09:38 AM
Hello Again,
Thought I should clarify something. I can get the nuber of the button that was hit to show up in the report, but I want the text from the button that was hit to show up in the report.
GSinMN
08-04-2014 09:42 AM
Thanks M.Haarman. Exactly what I was looking for. Glad it was easy.
GSinMN
