NI TestStand
Link between num socket and threadId
As said in the object, I wonder if there is any relation between threadId and the UUT position (socket) ?
FranckH
(1,456 Views)
I guess I don't understand why you need to correlate them.  Sockets can have more than one thread.  Besides, at any point during the execution you can grab either (Thread.Id or RunState.TestSockets.MyIndex).  So correlating them doesn't make sense.
Maybe if you explain the need a little more there might be a better way to accomplish what you want.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,428 Views)
I'm getting location from output message:
case UIMessageCodes.UIMsg_OutputMessages:
    OutputMessages outMsg = e.uiMsg.ActiveXData as OutputMessages;
    OutputMessages appOutputMessages = _engine.NewOutputMessages();
    outMsg.CopyMessagesToCollection(appOutputMessages);
    outMsg.Clear();
    foreach (OutputMessage outputMessage in appOutputMessages)
         foreach (Location location in outputMessage.ExecutionLocations)
From this location, I could get a thread id:
location.ThreadId
So I was wondering if I could get Num Socket from this information ?
Meanwhile, I've successfully implemented a complex but functionnal solution:
foreach (Execution item in _appMgr.Executions)
    if (item.NumThreads > 0)
         PropertyObject seqContextPO = item.GetThread(0)?.GetSequenceContext(0, out int frameId).AsPropertyObject();
         int testSocket = Convert.ToInt32(seqContextPO.GetValNumber("RunState.TestSockets.Count", 0));
         List<Execution> socketState = new List<Execution>();
         for (int Iindex = 0; Iindex < testSocket; Iindex++)
             socketState.Add(seqContextPO.GetValVariant("RunState.Root.Locals.ModelPluginConfiguration.RuntimeVariables.PerSocket[" +                          Iindex.ToString() + "].Execution", 0) as Execution);
             if (socketState[Iindex].Id == location.ExecutionId)
                 iSoc = Iindex;
With iSoc the socket index. Maybe there is a more straightforward solution, but I can't find any.
FranckH
(1,421 Views)
Accepted by topic author FranckH
int iSoc = Convert.ToInt32(seqContextPO.GetValNumber("RunState.TestSockets.MyIndex", 0));
jigg
CTA, CLA
testeract.com
(1,412 Views)
Thank you !
(1,400 Views)
