05-15-2018 10:53 AM
Hey all, I'm trying to write a simple VI that receives a path to a .seq file as input and then runs that TestStand sequence. So far I've managed to put some code together that runs but isn't running my sequence. I get no errors, it just doesn't run the sequence. Thoughts? It seems like this should be extremely simple but I'm having trouble finding a good example of how it should go. Code included.
05-15-2018 11:52 AM
this example should do what you want:
https://forums.ni.com/t5/Example-Programs/Executing-Sequences-Using-the-TestStand-API/ta-p/3527309
(its now included in teststand in the public directory)
03-23-2021 08:05 PM
The following link is showing -You do not have access to view this page or to perform this action
can you share the link again.
thanks
03-24-2021 04:31 PM
Try navigating to the below path for the suggested example (modify it for your TestStand version):
C:\Users\Public\Documents\National Instruments\TestStand 2020 (32-bit)\Examples\TestStand API\Executing Sequences Using API\LabVIEW
