NI TestStand
Labview "Getting Started" Window
Everytime I run my testand sequence it loads up labview (2010) "Getting Started" window which interfere's with a VI I'm running as part of my sequence.  Is there any way to prevent labview or the getting started window from constantly popping up?
Message 1 of 9
(5,226 Views)
Message 2 of 9
(5,217 Views)
I'm wondering if anyone has other ideas to solve this problem.  I'm worried about switching to run-time engine without doing a deployment, and I don't like the idea of touching every Labview Step just to change a property.
I was considering launching a DoNothing.vi from my user interface, but that is less than ideal.  Would prefer to just disable that window completely, but that option is only applicable when opening Labview doesn't make a difference when running Teststand engine from custom user interface.
Although doesn't the Teststand Sequence Editor always stay in front?  hmm.
Kevin
Message 3 of 9
(5,065 Views)
Minimize LabVIEW before starting your sequence. So long as it's been minimized in Windows then I've yet to see it show the Getting Started screen.
CTA, CLA, MTFBWY
Message 4 of 9
(5,061 Views)
I pretty much always open LabVIEW and make sure it is fully up and running before starting TestStand.  I find it helps the loading process.
Message 5 of 9
(5,053 Views)
Both are reasonable solutions when a knowledgable engineer is running the software.  However we have operators running a custom UI.  I have already had situations where the operator closes Labview in the middle of the test when the Getting Started window pops up in front of the UI.
Kevin
Message 6 of 9
(5,042 Views)
You shouldn't be using LabVIEW Development on deployed benches. Deploying your code and running the LabVIEW Run-Time Engine is a much better solution.
CTA, CLA, MTFBWY
Message 7 of 9
(5,039 Views)
Hi MMP14,
Do you have the LabVIEW environment option to skip the getting started window enabled?  This will prevent the getting started window from appearing if your sequence is starting LabVIEW.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
Message 8 of 9
(5,025 Views)
Tried that option, and it only disables the getting started window when I open Labview from the start menu.  It still shows it when my sequence executes from the custom UI.
Eventually I will do a full deployment on the station, but right now we are kind of a hybrid.  Still doing develovpment in addition to testing prototype hardware.
Kevin
Message 9 of 9
(5,021 Views)
