NI TestStand
LV Channels breaks VI when loaded into RTE in TS Seq
Hi Forum members,
I have attached a simple example of the issue I am facing. This VI contains a simple channel wire writer & reader for waveform array data type.
While using LV dev as an adapter, everything loads and runs fine. When configured to use LV RTE, TS could not load and complains that the channel wire dependencies could not be found and causing a bad linkage.
Historically, I had faced the same issue on other computers and I solved them by clearing out the Channel cache from Documents\LabVIEW Data\2019(64-bit)\ExtraVILib\ChannelInstances\
Things tried,
  • Clear Channel cache
  • Open VI, delete the channel wires and recreate from scratch on the end-computer
Appreciate your thoughts, anyway going to create a support ticket with NI on this.
LV 2019 64-bit f2
TS 2019 64-bit f2
TSM 2019 64-bit
Win10 64 bit
Tried on an 8881 controller and also an HP laptop.
In order to observe this error, open the VI and save it (to recreate the channel instance on your computer), open TS, change adapter to RTE and run seq analyzer.
BTW - not configured for version-independent RTE, so there should be no issues with searching for dependencies
Santhosh
Soliton Technologies
Message 1 of 1
(1,283 Views)
