NI TestStand
LABView application calling from TestStand
Hi
I have a top level LABview application (VI) which calls 4 other  VI's, does some a simple
computation , and displays 3 graphs as an output.
I want to integrate and  run it from TestStand and get the results to the teststand report including data as well as graphs.
However with my knowledge of teststand, I am not able to create a testsequence that performs this task.
please advice.
Thanks in advance
Holy
(3,588 Views)
Is it a labview application (exe file) or the actual top level VI that you want to interface with teststand.
If, its the VI, then you can save the result arrays into some teststand Locals directly from your VI conector pane (assuming you are using TestStand 3.x). Then use some None Adapter steps types to act on each of your array data.
If your report is HTML, you can use the report option to insert a graph based on your result array.
Regards
Ray Farmer
Regards
Ray Farmer
(3,584 Views)
Hi Ray,
Thanks for the response. I am using TestStand 3.1 running on Windows 2000.
My Labview application is not the exe file, it's the actual top level VI, which calls 4 other  VI's.
Could you please tell me how to save result arrays to Locals.
by going to View ---> Type Palette.
or some other way?
another thing I didn't get the following line...
"Then use some None Adapter steps types to act on each of your array data."
As I told you I am very new to TestStand, so need more help from you.
Holy
(3,573 Views)
Hi Holy,
Looks like you have a similar thread running http://forums.ni.com/ni/board/message?board.id=330&message.id=8088 and Santiago D. has provided a good example which should met your needs but I will be happy to provide maybe a simpler solve for you.
Regards
Ray Farmer
Message Edited by Ray Farmer on 08-31-2005 08:21 AM
Regards
Ray Farmer
(3,571 Views)
