hendric -
I had forgotten that in TestStand 1.0.x, the file was called "StationModelReportOptions.ini". In TestStand 2.x and 3.x TestStand saves the file as "TestStandModelReportOptions.ini"
Did you install on top of an older version? I assume that you did because TestStand 3.0 fails to properly read the TestStand 1.0.x file. This worked in TestStand 2.0, but we had to restructure the file format for various reasons and it appears that reading the older file for report options just does not work anymore.
My suggestion from before to rename the file was wrong, just delete the file whether it is named "StationModelReportOptions.ini" or "TestStandModelReportOptions.ini". You should be all set to go.
Scott Richard
son (NI)
Scott Richardson
