Hello Bob,
In TestStand, the sequence file version is stored in RunState.SequenceFile.Data.Version. As far as I know, there is no "Built-In" method of preventing one sequence to be executed according to the sequence version. However, it is not complicated to create this functionality. You may modify the process model in order to query the database (using database step types) for the approved version and if it doesn't match with the property mentioned above, you may jump to the "END" (using a goto step).
If you don't want to change the process model, you may modify your sequence instead of the process model. In this case, you may include in the "Setup" Step Group, database steps to query your database and jump to the END if the versions don't match.
Robert
o Piacentini
