From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
NI TestStand
Is there a way to programmatically read TestStand type version information?
In the Type Palette Properties page for a TestStand type, you can specify a
version number for the type.
Is there a way to programmatically query the type version of an instance of
a type at run-time?
Bob Rafuse
Etec, Inc.
(3,046 Views)
Hi Bob,
since the instance of a step doesn't have a version, you have to get the version of the type of step.
To do this in TestStand itself, I first have to find out what type the step is, using the step itself as an activeX reference. From the step type, using it as a property object I get the typeversion.
Hope this helps.
Sacha
I've attached an example in TestStand 2.0.1 which gets the version of a statement step in MainSequence - go to Mainsequence and Run Mainsequence (i.e. not using process model)
// it takes almost no time to rate an answer Smiley Wink
(3,046 Views)
Sacha,
> Hope this helps.
It does. Works great. Thanks!
Bob.
(3,046 Views)
