William,
As you alluded, TestStand 2.0 has better solutions to this problem than TestStand 1.0.x. These include
1) Executing the subsequence on a different thread but under the same execution. The file globals are then common to the calling and called sequence. The improved Sequence Call step type gives you this option.
2) There is a new sequence file property that provides that "All Executions Share the Same File Globals".
The reason that the file globals are not shared between your 2 sequences is that they are each executed as separate executions. That is, they are each executed using the NewExecution method. With each new execution a run-time copy of the sequence is made, including the file globals.
I am assuming that you want to execute the subsequence asynchronously (i.e. in parallel) to the MainSequence and therefore must use the NewExecution method to do so. Since you must use TestStand 1.0.3 then the best option is to pass the file globals to the new execution as sequence parameters. It sounds like you tried this but had difficulties. The steps to do this are:
A) Create parameters in your called sequence that mirror the file globals that you want to pass from your MainSequence.
B) Create a new data type that is a container. The subproperties of this container must mirror the parameters in your called sequence. It is important that they are in the same order as the parameters.
C) Create an instance of this container data type as variable.
D) Pass this variable as the parameter of the NewExecution method.
I have attached an example of how to do this. I have 2 file globals that I want passed, Number and String. I have another file global that is an instance of the parameter container that I pass with the NewExecution method (could also have made as local variable). Any time I update the values of the container�s subproperty, the changes are available in the executing "subsequence". Therefore, I must update the value of these container subproperties every time I want to have access to new file global values. There is clearly some redundancy here in that my MainSequence must copy the Number and String values to the container subproperties. If fact, it may be better to simply delete the Number and String file globals and simply use the subproperties of the container directly.
You probably have to play around with the example to synchronize the change of the file globals with the message popups in the subsequence. In TS 2.0 I would have synchronized them with the new synchronization step types.
