08-26-2020 02:24 AM
Is there a way to get all dependencies (dll's, vi's,...) of a sequence file in c# without workspaces?
Solved! Go to Solution.
08-26-2020 05:47 AM
I don't use C# but hopefully you have LabVIEW (to view the attached) and can translate it to C#.
I have done this sort of thing in the past for VIs, not for DLLs but I think it can be modified to include DLLs. I found the process a bit convoluted (see attached VI). Maybe there is an easier way to do it that I don't know about (there usually is).
What I did was to use the TestStand API to get the paths to all the VIs in a sequence (see attached VI) and then use Get VI Dependencies (see below) to get the paths of the Dependencies from the reference of each VI found to build up a list. See attached code for getting the VI paths from a sequence. Its a bit rough and ready and will likely give you duplicates if the same VI is called from multiple places in a sequence but I think it should work and scaled to include DLLs and anything else you want.
Steve
08-26-2020 05:50 AM
Thank you, I already got a solution for c#, will check your solution out too.
08-26-2020 05:53 AM
Hi Seau1,
Can you share your solution for c#, please?
08-26-2020 06:01 AM
Had to put it in a .txt file as i cant format it here. At the moment it only detects VIs and Dlls
10-04-2021 07:25 AM
Hello, i cannot download any of those attached files - is it a problem in my company, or is it a problem of NI?
10-04-2021 07:45 AM
@brosian I can still download the files, seems like there it gets blocked by your company
