07-19-2005 09:47 PM
07-20-2005 10:45 AM
07-20-2005 10:45 AM
07-20-2005 11:01 AM
Sorry about that,
There are two ways as I was saying:
1. You can configure the CVI adapter to Execute Steps in a External Instance of CVI (requires CVI 6.0 or greater).
Only go to Configure->Adapters and select the LabWindows CVI adapter and click on configure and select the corresponding option.
After that set a break point in the step that you want to debug.
An external instance of CVI will be launched where you can set break points and step into the code.
2. From CVI Specifying an external process:
In CVI go to Run Specify External Process and enter the seqEdit.exe as the program name (you have to browse to the location <TestStand>\Bin\SeqEdit.exe).
As the argument you enter the name of the sequence file you want to debug.
Now just select Run->Debug SeqEdit.Exe
The Sequence Edtior will be launched and you can set break point in your CVI code and step into it when the step is executed.
Check the Using LabWindows/CVI with TestStand reference manual for more information.
I hope it helps you to get started.
Regards.
07-20-2005 02:55 PM
Thanks Antonio,
I thought I read somewhere that it could be done. I was told by collegues that it could not.. 😞
I will try and report how it worked..
Thanks!
05-10-2021 12:48 AM
Hi Antonio,
I come here for the same question. You know in the previous days, I always use the first way do enter into cvi and it successfully. Launch a external CVI run project and then break on the function. The .c file will on the top of the window.
But these days, I have a new PC install the TestStand 2010 and I try to enter into the CVI (using the same CVI project), it also load the cvi run project, but it is strange that do not break, even there is no any other source file in the top of this CVI run project, just with a tscvirun_supp.c.
